- Jun 1, 2018
- 16,019
- Vinyl
- Hayward Aqua Rite (T-15)
GreatAfter adding baking soda to raise the TA and then dosing with 0.3 fl.oz MA followed later by 0.5 fl.oz of MA, my pH is now 7.7 and my TA is at 75! I really think I just blew up the pH on fill day between the main pump running on low all day to bring the cold water up to temperature and me running the jets for a long time while after I added the calcium to raise the CH.
I'm not sure what you mean by the two-bottle method or the chlorine neutralizing solution. My pH test is just a single vial with some phenol red. But I doubt it's high chlorine throwing it off. I was getting these readings before I added any chlorine.
Fill water TA is 70 with a pH of 7.6.
Now just manage ph when it rises & the ta will fall further mitigating the frequency/intensity of ph rise.
No need for baking soda unless ta goes below 50. This will probably rarely happen if you aim for mid 7’s with your acid doses.
Also, if you need to use baking soda in the future go light handed with it. A little goes a long way in a small spa. You can always add more later. The same goes for all the chems until you are sure of their effects/ have your volume pretty dialed in.
