Hey all,
I have an air leak in my filtration system. I believe it's on the suction side and I can't find it. It's so bad I need to prime it in the AM with the hose to fill the pipe back up from the filter basket to get it to run. After that it will run all day. But the next AM it will just run dry. I've checked:
Filter basket o-ring - good
water level - good
vacuum - unplugged that to make sure it wasn't coming in through the hose
DE filter o-ring - good - no leaks
Some thoughts and recent changes in the system to consider:
- Recently I had my pool drained and acid washed and refilled. Seemed to run OK after that.
- Also I replaced the thermister on the heater. It didn't seem to go in as far a the old one, but it works. Is it possible that air can be getting in through that even if the heater is not engaged?
I have a slow water leak out of the pipe coming out of the top of the filter. Could that be the source of air getting in? See pic.
Anyhow I'd love to hear some insight.
Jon
water level - good
Jon
