Canopy for Spa
gmike09
68
Atlanta, Ga
Hello All
I have an inground pool with a spa attachment. Being in Georgia it is not cold enough to close the pool. However there are days were it is a little too cold to swim, but ok for sitting in a hot spa. I want to set something up to use it on days where it is not so warm, but not cold either. I was thinking about setting up something like a portable canopy with walls around the spa. My major concerns keeping the spa area some what warm and not causing a mold issue. Has any one ever done something like this before or have a similar setup?
If it’s outdoors and not completely sealed it should be fine. Most have some vents at the top.
Many people cover their spa directly so it retains its heat but I think you’re more concerned with the ambient temperature for the user when getting in & out?
Fwiw we don’t have any walls around our standalone spa and we use it year round even when it’s below freezing outside. Hop out, dry quickly then don a robe & slippers.
You’d definitely want to secure said canopy to the ground so the wind doesn’t carry it away and cause damage like ending up in your pool.
Reactions: gmike09
