Cannot reconfigure pool calc
iskubits
0
42
Toronto, Canada
I guess I got pretty good with pool math that I never had to use Pool Math app till today. when I installed it, all I could configure was pool name and volume. Type of pool, or Type of acid to lower PH cannot be changed, those are "Greyed out". What am I missing?
Thank you,
Igor.
Did you set up the pool in Settings? Touch the gear icon
Be sure you have a test results entered to get to chemical adjustments.
Exactly the issue. It does not let me change "Type of Pool" from Vinyl to Plaster in the settings (when I touch the gear icon).
It also does not let me change "What will you use to lower PH?" from Dry Acid to Muriatic Acid.
Just curious. And posting in case someone else has the problem... how did you resolve?
For me, when I first setup Pool Math a month ago, I was trying to click/select my selections and it took me awhile to realize you don't click/select you have to SLIDE on your phone screen to select a different option. LOL. I felt pretty dumb but... I'm sure others have made that same mistake.
