Cannot get good color match on the pH tester that comes in TFtest kit
CFlaPool
166
Satellite Beach, Florida
Pentair Intellichlor IC-40
I can never get a good color tone match on the plastic kit. I do get good matches on our 25year old Guardex test kit using porpoise test bottles from pinchapenny. Does anyone else have this problem, or is it just me? Also, is there a recommended best tool to measure pH?
The pH test frustrates me as well. :crazy: Best things I do for that pH viewer is ensure I have a light background behind the viewer. I also like to do the test outdoors with natural light around me. That, coupled with some beige home siding helps. Lastly, when it's 7.5 or lower you should really tell. It will be orange or lighter. It's those 7.7-7.8 and above, the darker lavender shades, that are tough to call. But if it's that dark, you probably need some muriatic acid.
A similar report was made here...
@Sarah and Nate may want to make note of this.
Reactions: DigitalGuru
Two additional techniques:
1. Try holding the block sideways or upside down. Sometimes that helps distinguish colors better. I also use two old hotel keycards to mask off areas and narrow down my decision.
2. To get a consistent backlight, hold the block in front of your computer monitor with a blank white screen displayed (I use Google's homepage).
I agree with that other (marathon) thread that the TF color blocks look faded. It looked the same as mine when I have a pH of 7.8.
As a test, try using 4 drops of the pH reagent instead of 5.
I have the older comparator block (always stored inside in a dark cabinet) and I have an easier time discerning the pH reading when using 4 drops. Holding the comparator against a white background helps as well.
