Welcome to the forum!
You need to follow the SLAM Process. To do that, you need a proper test kit. What test kit are you using?
I suggest you read ABC's of Pool Water Chemistry.
Yes... we need test results from a reliable test kit such as the TF100 from tftestkits.net or a K2006C from Amazon. You'll get more for the money with the TF100. Read up on the suggested links n order the test kit. You'll be ready with knowledge when you get it and the SLAM will be easier.
