I know that if your CYA is high, then you need to keep your FC high. On the chart, it says that:
CYA=100ppm
Minimum FC=8
Target FC=11-13
Shock FC=39
Is it that at CYA=100ppm, it is just not possible to reach those FC targets? I mean if I bought enough bleach wouldn't I be able to reach those FC targets? According to poolmath (unless I have it wrong), it says you just need 4 gallons of 10% bleach to reach Shock FC=39.
Okay let's say you reach your target FC with high CYA. Doesn't the CYA then minimize FC loss? So although you need to maintain a FC=13, once you reach it, why can't you maintain it?
Or is it that the higher the FC, the greater the loss and so it becomes much more expensive and difficult to maintain that high FC (which seems to contradict that high CYA would minimize FC loss).
CYA=100ppm
Minimum FC=8
Target FC=11-13
Shock FC=39
