Hi everyone, I have an in-ground liner pool that came with the house, we think it's about 30 years old. I'm looking to change the light to LED but when I removed it the compartment containing the connections was full of water. There is no seal around the bulb and it looks like the last guy to change it tried to seal it with silicone.
I've ordered the new bulb and a seal however, when the seal arrived it was about 3 inches diameter, about half the size it needs to be. I have been told that it fits around the bottom of the bulb and goes inside the container but I checked it out and it just doesn't work. I had thought about getting a larger seal for the point where the bulb contacts the container, however, the surface of the bulb at that point is not flat so this wouldn't work.
My next plan was to contact the manufacturer, however, there are no markings on the fittings. It's been suggested it is a SAm light but the only ones I can see online are different.
So, I'm going to post some images of the light and bulb, if anyone can help me identify it I'd be very grateful.
Kind regards
Ian
Kind regards
Ian
