Can you identify these plugs?
pb4uswim
578
Michigan
I have two plugs from the last time my pool was closed. One I’m sure goes to the return lines to seal them. The other one was for a blow out pipe. They both have the same number but the difference is that one has a “2” and the other has a “4”. I’m sure the “2” is a standard 1.5 inch plug and was used for the returns. I’m not sure what the “4” is an I can’t find one on line. They don’t show a numerical code. Only the 1.5 inch plugs (the “2’s”) come up. But even those don’t show/mention the “2”. I’m trying to buy an extra “4”.
As far as I can tell from searching they are all SP-1022_C 1.5 inch plugs.. Is the #4 one the same as #2?
No, it’s not the same. It seems like it has different threads. It is also a little bigger. I’m sure I can match it at a pool store or plumbing store but I was trying to get my supplies ready to close and obviously, it’s easier to do, if possible, on line.
Can you show both sides?
The 2 and 4 are probably the plant numbers where the plug was made.
The "W" means white.
They should be the same plug.
Get a 1.5" female thread fitting to screw the plugs into to see if they feel the same.
Reactions: pb4uswim
They both look exactly the same with the two bars running the width of the plug. No markings. I’ll look at them better tomorrow, but after my first look, I didn’t think they were the same. I think the one with a ”4” is two inches. I’ll measure it. Thanks for the link.
I think that they are the same.
They are not going to make two different parts with the same part number.
The 2 and 4 probably identity which city the plug was made in.
I looked at them this afternoon and I’m embarrassed to say that they are all the same plug. I could have sworn that the “2” was different from the “4” when I matched them up yesterday. Not only are they the same, one on the plugs is a “3”. So not sure what that designates, but city or plant, etc. seem likely. Oh well, on to buying some spares for closing the pool preparation. Thanks and sorry.
