Our concrete contractor ended up doing some amateurish work while installing the concrete around our new fiberglass pool. They didn’t secure the form right on one edge and the middle bowed in like 3 inches, creating a curved edge on a rectangular pool. They also messed up the corners and didn’t align them quite right.
They claimed they could fix the live edge by chiseling it back, which they did, but then they added a whole bunch of concrete patching, using the silicon form to shape it. It looks like utter garbage, and of course the color doesn’t match.
In addition, they pressure washed the concrete, apparently too early or with too much force and put a bunch of squiggly scars in the concrete, which they then filled with the same darker concrete patch, and then tried to use the antiquing powder to make it not so obvious. Spoiler alert, it’s super noticeable and awful.
I really want them to rip it up and re-do it. At least that patched up edge, which I’m sure is going to start cracking and flaking in a year or so, but ideally the rest as well. I’m not sure if this can be done without damaging the pool.
Suggestions welcome. I’m losing sleep over it.
Original edge issue:
The “fix”:
The scarring with patching:
The “fix”:
