CaliMar VS Pump Issue - Freeze Protection
NoCatharsis
7
Dallas, TX
CircuPool Edge-25
The CircuPool SmartFlo manual has the following description.
The B+D manual has instructions for changing freeze settings.
I ran through the instructions on the B+D pump, but applied to my Calimar-branded pump. The freeze settings appeared to adjust and everything seemed to work exactly as described by B+D while I was in settings mode.
However, upon saving the settings, the Calimar pump seems to completely error out. The RPM just reads zero from that point on, and I was not able to adjust ANY setting nor even turn the pump on at this point. The Time LED is lit and shows the current time, but I cannot select anything else. The solution was to cycle the power, then I was able to get back to my Scheduled/Manual operation.
Has anyone had a different outcome with the Calimar specifically? I am going to assume Calimar has removed the temperature sensor or disconnected it from this programmed functionality, because there is no mention whatsoever of this "secret" menu in their operation manual.
