Phosphates tested at 1300 ppb, they want to see 300 ppb. So should I use a remover or change the water. It is causing the monitor to give me an error message saying the salt level is too high. Salt level tests perfect. Thanks for any help
Says who ? The spa or the pool store ?It is causing the monitor to give me an error message saying the salt level is too high.
Says who ? The spa, the pool store, or a K-1766 test kit ?Salt level tests perfect.
Ok, GREAT.Have hours into it.
I haven't read every post here, but I'm getting there. I haven't seen one where phosphates mattered for salinity. I've only seen a 3 fingered handful (fireworks accident) that phosphates mattered at all, but the pool stores sure do LOVE to make them out to be the bad guy.The only bad number was the phosphates?
If the phosphate part was true, with ooooooooooooodles of SWGs here, we'd have that problem arise alot. Especially because most of us never test or treat them.from what I understand these systems “assume” the salinity level by measuring current through the cell. There’s no separate salinity sensor. The mfg stated that the high phosphate levels can screw with the current reading
Does it just say "Too High" or does it give a reading?It is causing the monitor to give me an error message saying the salt level is too high.
Ask them exactly how it "screws" with the readings.The mfg stated that the high phosphate levels can screw with the current reading
You need the K-1766 to get an accurate reading on the chloride level.James W
Seriously?
James W
Seriously?
