Any thoughts on why I am consistently getting results for calcium hardness that are higher than two local Leslie pool stores? I am consistently getting results in the range of 275 to 300 ppm, and two separate Leslie pool stores are consistently getting results of 200 ppm or less (170 ppm today). I have a TFTest kit, and I noticed Leslie uses a different method--they add an eye dropper full of a reagent, add 5 (?) drops of another reagent that turns the solution red, and then add a final reagent until the solution turns blue. They then multiply the number of of drops by 10 to get the ppm of hardness.
Note that my Cyanuric acid level has been dropping recently, which would seem to indicate dilution of my pool water--we have had a number of days of heavy rain such that I've had to drain water from my pool. Yet during this same time period, my hardness results have not been dropping, which makes me concerned that my test results are not accurate.
I have fresh reagents that I bought this year, and I'm following the test instructions as carefully as possible.
Any thoughts?
Any thoughts?
