- May 23, 2015
- 24,590
- Plaster
- Pentair Intellichlor IC-60
Maybe @JoyfulNoise can enlighten us on the GAC pre-filter he has.
I use WaterTec for my softener. They are a local AZ company and completely in the water treatment business. It’s the entirety of their business so they know what they are doing.
I have their dual eliminator system. It looks like a single tank but it’s actually two tanks stacked vertically on top of one another. The upper tank at the distribution head is where the GAC is located. I forget how much GAC is in that tank but I’d say it’s a few pounds at least. The water hits the GAC first and it removes all the chlorine/chloramine/VOCs as well as iron and heavy metals. Then the water flows down into the resin tank where calcium and magnesium are removed. The treated water then exits up the center standpipe.
If you wanted to do a GAC prefilter on an existing system then it would have to be a separate filter from the softener. It would need to be sized correctly for plumbing pipe diameter as well as flow rate. My suggestion would be to do a setup, if you have the available space, where you do a sediment trap (spin polypropylene mesh) to remove suspended solids (dirt, silica, etc) and then a GAC filter to remove chlorine/chloramine, and then the softener. In that type of setup, you would be looking at changing the sediment and GAC filters either annually or every 18 months and then the resin would be changed every 10-15 years. Sediment and GAC media are cheap compared to cationic softener resins.
