33k gallon vinyl pool, SWG and sand filter. Recently I added a ton of calcium hypochlorite to treat an algae outbreak after my VS pump cut off for 2 days following a power blip. I've done this previously successfully however this time I guess I hit a break point and turned the pool milky white. I did a calcium test and stopped counting after I reached the 1K ppm mark. Other than being unsightly is this a problem? Will the issue eventually correct itself after many rains and fills? Trying to avoid draining my pool because I recently did this to correct a high CYA issue and I don't want to have to add a bunch of sand, etc back in. But if this can cause big problems I need to correct it.
