Yes, you have some CH room to play with so it's fine. Fairly soft water in your area as well it would seem. Once you get the CH to about 300-350 you should be fine. Unless you change water due to heavy rains or something, your CH will slowly climb over the summer. As Marty noted, watch those granules though so they don't just sit on the pool surface. They might leave some bleached spots.
