Hello,
I just received my TF salt pro kit and I added the C 600 meter add on.
Based on the description on the tftestkits website, it seems like a pretty accurate tool. Is there any benefit of me using the drop test to check PH, salt, TDS versus just using the meter and calibrate it on a regular basis? I also have the basic ph tester fr, tftest kits so I could compare PH value between the two.
Thank you!
Thank you!
