C600 multifunction meter - accurate?
julien2101
23
Las Vegas
Hello,
I just received my TF salt pro kit and I added the C 600 meter add on.
Based on the description on the tftestkits website, it seems like a pretty accurate tool. Is there any benefit of me using the drop test to check PH, salt, TDS versus just using the meter and calibrate it on a regular basis? I also have the basic ph tester fr, tftest kits so I could compare PH value between the two.
Thank you!
Whenever the meter gives you an unexpected reading confirm it with the chemical test.
Otherwise use whichever one is most convenient for you.
When you have any water chemistry problems it is best to go back to the chemical tests.
Reactions: julien2101
