- Sep 12, 2023
- 1
- Vinyl
- Hayward Aqua Rite (T-15)
I have the exact same issue as this user with my Hayward Aqua Plus system throwing a Communication Error. Ironically, I live in the same area as the original poster and my pool pump setup is identical (where my 220v pump outlet is controlled by a paddle switch and a double 20A breaker). I will need to bypass the relay on the Hayward Aqua Plus so it doesn’t continue to short cycle my single speed pump. Per the earlier detail in the post, I will connect the one set of wires (terminals 2 & 4) together with a wire nut and the second set of wires (terminals 6 & 8) together with a second wire nut. Do I have that correct?
