Well, the rest of the day was spent doing some more rust conversions, and some research. That little 8 oz bottle I bought goes a long ways! I'll probably only need 2 more bottles.
The pump after the rust conversion. I think I might still paint it... but then again, maybe not.
Which brings us to the research I did.
I started looking for through the wall lighting. I found a total of two. Hayward's Elite and Sta-Rite's Sunstar. Both 12v systems. That's pretty much it, unless someone else knows of more. Neither one can I conclusively find what type of bulbs they use to see if they can be changed with something more cool like those multi-color LED bulbs. Yes they come with colored lenses, but that seems so manual like. What if I wanted Tahitian Blue, or Miami Pink? Take apart the light, change the lens... blah. Of course if I had an inground, my choices would be endless!
Then it was off to pumps. I figure the first electric bill I get after startup, I'll probably be changing pumps real quick. Looked for a while, but finally found a two speed pump. Pentair dynamo, $220 to $300 for a 3/4 hp depending on where you buy it.
I think I'm going to go with Gladon's perfect pool bottom kit, unless someone has a overwhelming reason not to. Haven't decided on the wall foam yet or not.
I've also run into a snag. I can't find the four verticals I need, nor the plastic caps that go on top. I have some emails out, just waiting on replies. If I can't find the verticals, I'll be doing some sheet metal work. They'll probably turn out ugly, but structurally ok, so I would probably hide those on the side of the pool that will never be seen, 'cept when mowing.
Not sure what to do if I can't find the plastic caps... I'm sure there has to be ones that are compatible, they look like any other cap on any other pool I've seen.
---edit---
Had a thought on if I can't find the two missing plastic tops. I suppose I could leave those off underneath the deck. Seems so red-neckish though.
