Hey All. I feel like I should know the answer, but I don't and need confirmation.
We opened a bit later after a warm spring with a cover failure at some point. Pool was light green, but opaque.
I immediately started the SLAM and have held the FC around 24* for the last 6 days.
The water is now crystal clear.
Now I was slamming at 24 because I usually have my CYA at 70. It's actually somewhere between 30 and 40 but I didn't make it to the store to pick up CYA, so I figured I'd finish the slam and while the FC was drifting down, I'd bring the CYA up. Anyway. I'm going to do the OCLT tonight. I got up super early this morning to check it, but then realized I forgot to check is last night and so I had no comparison. It's not loosing much at night though.
But the CC. The CC has been between 1.5 and 3 the whole time. So I can't finish the slam because it's not below .5. What makes the CC go away? Am I right in saying that the presence of CC means the FC is still breaking something down.
Note, I did find a section of wall that missed getting brushed and was dirty, so I gave the whole thing a THOROUGH brushing. But that CC.... someone educate me please.
Here's test results from about 2 hours ago
FC 22
PH (didn't test because the FC is 22, but pre-slam it was 7.2)
TA 70
CH 200
Salt 2600 (bags from Costco still in my car, just need to dump them).
CC 1.5
CYA 40? (today it looked like 30, on a bright sunny day it looks like 40). Either way it needs to come up at least 30
Not sure if this applies, but I put Pool/RV antifreeze in my lines, and normally blow it to waste, and blow it out of the returns (not into the pool), but do to a plumbing issue (a stupid mistake) I accidentally blew it into the pool. No idea what effect this has on the chemistry.
So do I just keep on slamming until the CC is down? The water clarity is night and day better, but the CC hasn't budged.
Thoughts?
FC 22
TA 70
CH 200
CC 1.5
Thoughts?
