OK, so we're in Texas, where it (almost) NEVER gets cold enough to worry about winterizing our pool. About 13 years ago, we installed a 32x16 Doughboy with 7' deep end, buried with about one foot remaining above ground, and a large deck/railing surrounding the pool. We never close it for winters and run the pump 24/7 on LOW. We've never had a problem with freezing until NOW! Months after the initial install, we decided to add another return and couldn't get two pipes at the filter to match up, so used a "rubberized pipe" section to connect two pipes.
Assuming that running the pump on low was the reason for 1" ice forming in the pool, I changed the pump to high (which it has never been put on until now). It took the pump a few seconds to kick back on, which concerned me. Well, the rubberized pipe section clamp popped off overnight and water spewed out all over the filter unit and insulated above-ground piping, creating a rather beautiful icicle creation! That drained the pool to below the skimmer and the pump was not happy this morning when we rushed out to turn it off! The ice is too thick on the equipment to do anything with it at this point. I broke up the thin ice in the pool in several places and tossed four of our foam float boards on top of the open water. I expect the filter already froze during the night.
We will finally get above freezing, up to 34, tomorrow and upward into the 50-60's (thank goodness!) from there. Should we just leave things as they are at this point or attempt to remove the filter plug, if we can get through the ice? I assume when we hit 34 tomorrow, maybe we will have enough thawed that we might be able to pull the water hose out and fill the pool back up and hopefully turn everything back on. How soon should we be able to tell if our zeolite filter is damaged inside, as well as the pump? And how will we know if the buried pipe to the far return has cracked? I don't recall how deep we buried it, but it's at least 12-18".
So I guess we need to rethink things this summer and make some changes to our pool setup to avoid this ever happening again....that once-every-fifty-years real winter!
Thanks!
Thanks!
