I'm a winemaker by trade and am used to buying chems in bulk. In fact I have soda ash in house that I've used effectively to adjust pH. I just joined here and received invaluable info to my newbie posts. I'm waiting on my TF-100xl test kit and as suggested on the forum I loaded up on some Walmart Great Value low splash bleach (6% active Sodium Hypochlorite ) at $2.64/gal or a little over 2 cents/oz. It seems like that is the most economical way to go.
I have a per ounce analysis below but my main question is should I be looking for Calcium Hypochlorite to help maintain calcium induced pool hardness for my vinyl pool? All the pool suppliers sell bulk Cal-Hypo but chem suppliers I can get Sod-Hypo that is in the Walmart Great Value low splash bleach. Does it make a difference?
Second question - Has anyone found a source of bulk Sod/Cal Hypochlorite that is less expensive than about $2.70/gal of bleach?
I found liquid Sodium Hypochlorite here in a 5 gal pail for $120 at 12.5% active Sod-Hypo. This is about 19 cents/oz. Even though it's twice as a concentrated it's more expensive... hmmm
Then there is Calcium Hypochlorite from pool suppliers like this one. A 50 lb bucket is 800 ounces for $120 call it, so 15 cents/oz. They say 2 oz will add 1 ppm per 10,000 gals. If I need to add 2 ounces that's like adding a gal of Great Value. If it's 5 oz then it's $5.40/day. So not more economical.
12.5% Sodium HypoChlorite - 5 Gallons
ChemWorld 56 is a solution of 12.5% solution of sodium hypochlorite that is commonly used as a cleaner and in water systems. Stocked and ships from Atlanta, Georgia, Taylor, Michigan; and Salt Lake City, Utah.
www.chemworld.com
Pool Supply World
www.poolsupplyworld.com
