- Jul 1, 2022
- 78
- Plaster
- Hayward Aqua Rite Pro (T-15)
Hi...
So we had salt introduced yesterday. Started noticing bubbles coming out of both wall returns and one of the floor returns. First thing I thought was the water might be a tad low so I added about an inch. The bubbles then went away. But we noticed them again about 3 hours later. Texted pool guy and said the chlorine tablet feeder drawing in air and said to turn that that dial down to zero. So I did that but it was late and the pump was already off by that point.
This morning the bubbles started appearing again. There's nothing stuck in the skimmers. I cleaned out the pump basket-no air bubbles appearing in there either.
When I turn off the chlorinator the bubbles stop. Then when I turn the chlorinator on again, the bubbles reappear. Clearly that's the issue. But is this a normal occurrence for the first day or so using it? I have a call into our PB for someone to come out and check everything just to be safe. Below are the diagnostics from the Omni Logic app if that is helpful. Any info would be welcomed. New pool owner here and not quite sure of a lot of things just yet! Thanks
