Had a new inground chlorine vinyl pool installed spring 2017. 16,500 gallons, DE filter.
Around midsummer, started noticing some brownish/whitish slimy film floating here and there in the pool, also stuck along the skimmers. Am still convinced it was from new home construction next door when the contractors were sanding the new siding and there was dust everywhere for almost two weeks.
Had the pool closed in Oct with a mesh looploc cover. Opened the pool today and the entire liner was covered with the same brownish/whitish film. It's like the stuff multiplied. Attached are pics of a piece of it floating near the surface. It breaks up when I brush the liner and try to use the leaf rake to capture it. And it coats the inside of the leaf rake - attached is a pic of that as well.
Guy who opened the pool stated he had no idea what it was, which wasn't very helpful. Have the DE filter on now and will leave it running overnight. I suspect it'll be dirty by tomorrow considering how much film there is in the pool.
I can vacuum the slimy film away, but no one seems to know what it is, so I'm trying to identify what it might be so I can go about the best possible preventative maintenance. Any thoughts are welcome.
![20180505_163524.jpg 20180505_163524.jpg](https://www.troublefreepool.com/data/attachments/62/62323-4a461de383750df0149df285881c9030.jpg)
![20180505_163627.jpg 20180505_163627.jpg](https://www.troublefreepool.com/data/attachments/62/62324-deed9afd8430947b809be667e7a4ec3a.jpg)
Thanks.
Thanks.
