Hello TFP folks. New'ish pool owner here. We just bought a 'real pool' last April (2018) and I started using the TFP methods during an algae problem toward the end of the summer. I converted to bleach from pool store chemicals, and got the FAS-DPD chlorine test. The 1000GPH pump that our pool came with left much to be desired, and even after getting the CC to 0, the water was not sparkly or pretty. I tried and tried, but i don't run the pump 24 hours because someone is afraid it will blow up or break the pool or something while we are asleep.....also we had a terrible time keeping the pool covered this winter. Leaves and debris settled and rotted, turning the water brown and giving the water an odd smell.
So, last weekend i scooped all of the leaves and debris out. I dumped a lot of bleach into it and stirred it with the old pump last week , because, that smell! I ordered my current pump Intex 28633EG Krystal Clear Cartridge Filter Pump 2500GPH and I hooked it up yesterday. I let it run all day yesterday and today, changing filter every few hours (of course letting it rest all night) The water seems to be clearing up. I can easily see the bottom today. I'm hopeful the TFP methods along with the new pump will make this summer easier. But for now, I have brownish water with a smell that is mostly gone now. Here are my numbers:
Water temp = 69F
FC =8
CC=0
ph=7.2
TA=60
CH=0
CYA 0? it never got cloudy enough to cover the dot in the hth 6 way test)
1. Does anyone know much about the pump in my sig. specifically, the timer options. There are several options for 2 hours, 4 hours, etc...Is that x hours in a 24 hour cycle OR "on x hours, off x hours"? Building a case for running the pump overnight. Thanks, the directions weren't helpful here.
2. Can i ask for a suggestion on filter cartridges? The disposable ones are cheap enough, but they are a pain to clean, which im sure i shouldnt be doing and I'm wondering if they are adequate to filter smaller particles. I'd rather invest in some reusable filters.
3. Suggestions for covering AG pool next winter? I've tried to salvage the flimsy plastic tarp that came with the pool by hanging it over the swingset an sprayed it off with the waterhose, but i'm leaning more toward trashing it because it was a lot of work, and didn't help anything because of the wind rain and leaves combo.
Thanks in advance.
jennifer
Water temp = 69F
FC =8
CC=0
ph=7.2
TA=60
CH=0
Thanks in advance.
jennifer
