- Nov 12, 2017
- 11,907
- Plaster
- Pentair Intellichlor IC-40
Not sure if you're agreeing or disagreeing. Yes, it is exactly a "local acid wash." Just like the bigger version that destroyed my entire plaster surface. If you're applying enough acid in such a way to affect a stain on your plaster/pebble, then you are also affecting the surrounding and underlying plaster/pebble. That was the warning. It doesn't matter that the acid "dilutes" afterward into the pool. Your burning off some amount of plaster. And for a pebble surface, not so much the pebbles themselves, but the plaster that is holding them in place. As I mentioned, if you're OK with the results, then that's fine. But you are not just removing the stain alone.I looked on TFP's posts and many use some acid to remove metal stains which it looks like it was. The acid literally sits there for a second and is underwater which dilutes it quickly. Really no difference than adding it to your pool albeit this is much smaller quantity and basically like a local acid wash. If it keeps coming back I will contact the PB as my plaster is less than 2 months old...thanks all!
If you don't agree, that's fine, but the warning was as much for other folks as you. You claimed "I looked on TFP's posts and many use some acid to remove metal stains." And that's probably correct, that many do. But that doesn't necessarily make it good practice. Just as many acid wash their entire pool to make it look better. It very well might make it look better. But that is costing them a layer of plaster (however thin), and that will affect the plaster's longevity. Acid should be the last resort of stain removal, IMHO. One of our most respected experts quantified it in one of his threads, but I now forget the number he used. X number of years less plaster life per acid wash (I think it was 2 or 3, I apologize for not being able to share the stated number). Just want to make sure those two ideas appear together, so you and others can make up your own mind about this practice. If you apply acid to plaster in sufficient quantity, you will reduce the life of that plaster, because you are removing some amount of that plaster (or, at least, some part of its chemical make up).
Certainly I've made too big a deal about squirting a little acid at a little stain in a gigantic pool! Just be careful how you do it, and how often at the same stain, is all I really intended to say.
For all I know, the warranty repair is chipping out the flake by chipping out the surrounding plaster. Essentially the same thing! Perhaps my guy patched it afterward somehow, like a mini chip-out/replaster job. I didn't catch that. And I can't now find the spot he treated.
