I've read through all of the "How do I use Bromine in my spa" sticky more than once and have been through a lot of the threads within the Spa and Hot Tub forum. I'm having a hard time putting it all together, so I thought I'd ask a series of questions on a separate thread. Sorry for the long post and thanks for the help!
My Spa
Current test results (using TF100 kit)
Bromine (OTO) = 2
Bromine (FAS/DPD) = 2 drops, so 2.25
CC test from FAS/DPD = 1 drop
CH = 175
TA = 30
(I know that I need to make adjustments and understand how, but I have other questions as well)
Questions
My Spa
- old model (name plate says it was built in 1999) - 250 Gal - Balboa controls and Waterway components
- using ahhsome when doing water changes and sodium bromide when refilling with city water. Last flush on Jan 2nd.
- have a floater with bromine tablets... opening size set around 1/2 inch
- wife and I get in hot tub for about 30 minutes every evening
Bromine (OTO) = 2
CH = 175
TA = 30
Questions
- Start with a stupid question (but one I keep asking myself)... the instructions for the TA test says to wipe the R-0009 tip after every drop with a wet cloth... WHY?
- Sorry - I know it is unimportant, but is just one of those things that make me say "hmmm"
- Someone please explain outgassing.
- I've read about it in several threads, but am not grasping the consequences yet.
- I keep my hot tub covered all times except when in use. The pump turns on low 2x per day for 2 hours each time (I think) and also any time the heater kicks on... when it does, the ozonator is running. Is this causing anything in my chemical balance?
- Bromine levels and shocking with bleach - why, how much, and how often?
- the sticky says to shock weekly with bleach. I've been doing this, but my bromine levels remain escalated (max level on OTO test) for 2-3 days afterward
- 1st time I used 1 cup of bleach... 2nd time I used 1/2 cup... 3rd time I used 1/4 cup. In all cases, my bromine level has remained too high for multiple days - I've ended up taking my floater out each week for 2-3 days
- Should I be doing a different test with my FAS/DPD kit to understand more details of what's going on? If yes, what?
- TA target.
- I've read various recommendations - some as low as 50, some over 100. I understand that it is dependent on how the PH level behaves. Mine has been stable up to this week... it is the first time it has gone low. I've had to put SpaDown in it before to lower PH, so I was surprised to see it dropping
- The weather outside has been warmer this week, so the heater and thus the ozonator has been running less... could this have anything to do with it?
- Borates
- I think that I'm going to add borax to it... 50 ppm per the pool calculator instructions (15 oz)
- Is there anything else that I should know before I haul off and do this?
- I have Leisure Time spa down so I can use it to adjust the PH back into range after adding the borax
- Is there any type of testing I need to do for the borates ongoing? If yes, what is the best solution? The only thing I've seen so far is test strips
- Salt
- I'm also considering adding salt. Should I do this before or after the borates?
- 2000 ppm target?
- should I buy a test kit or just add the recommended amount and have at it?
- will the salt have an impact on my other chemical balancing efforts?
