- May 8, 2018
- 337
- Plaster
- Hayward Aqua Rite (T-15)
Hi, all... I have one broken return that I would like to fix but am not quite sure how to go about it, or if I should just call in an expert. I don't have a picture of mine at the moment, but it looks like this. If I unscrew one of the remaining intact returns, the male thread remains attached to the plumbing on the wall. On the broken one, there are no threads left; If I slide a finger inside of the return, I can feel where the fitting ends, but there really isn't much of anything to grab on to for an attempt to work it out (assuming it's pressed in and not glued and we all know about assumptions). I considered the idea of using a fine hacksaw blade to try to cut through some of the remaining fitting to see if it could be worked out, but causing further problems isn't on my agenda. Any thoughts of this are appreciated. And I can get a picture of the actual fitting later, if necessary.
