Brilliant wonders sheer descents - LED malfunction
Enjoytheview
19
Nj
Pentair Intellichlor IC-40
I have 3 sheer descents from brilliant wonders with LEDs in them. One of the 3 lights is not synced up to the other two. I can get one color to match up by manually cycling through but is there a way to correct this or to sync the lights up? This is all run through my Pentair control panel and lighting system.
Also, is there a way to access the other light color of my Pentair pool lights. It seems there are colors like cyan that I can get to through the scenes but I don’t know how to just pick one of those colors if they don’t show up on the ScreenLogic app.
Thanks for your help,
Adam
@Enjoytheview
To sync the lights, I believe you will need to disconnect them from power after setting the color you desire.
- set the single lights to the desired color.
- shut off the lights and disconnect the power supply to that single light
- turn power on and set the other two lights to the same desired color.
- shut off the lights and reconnect power to the single light.
Your lights should be synced.
Not sure how to select colors on the ScreenLogic app.
Hope this helps.
