- Apr 10, 2018
- 6,573
- Plaster
- CircuPool RJ-45 Plus
For Pool Math, you'll need to know the LC strength (in percentage, 10%, 12.5%).Also I have 2.5 gal jugs which is 320 fl oz, which is also not an option. Grrr...
You'll need a good amount of LC for the SLAM Process. Maybe 10 gallons???
Work on increasing CYA level to 30 ppm. CYA is sold as "chlorine stabilizer" at the big box stores. Use the "sock method" to add CYA.
Solid/granular CYA should be placed in a sock and the sock put in the skimmer basket or suspended in front of a pool return. If suspending near a return jet, ensure the sock cannot rest against the pool surface since the granules are acidic and could potentially discolor the surface. After adding CYA you should leave the pump running for 24 hours and not backwash/clean the filter for a week. After soaking for about 30 minutes, squeezing the sock periodically will help it to dissolve faster. Test and dose chemicals in your pool assuming the amount of CYA added is in the pool according to Poolmath. CYA can be tested the day after it is fully dissolved from the sock.
Me too.I am somewhat surprised that your CYA was so low. I had expected that the previous owners only used pucks (my assumption) and thus the CYA would be high.
@tkbutler4, how were you chlorinating the pool? Any frequent use of tablets or solid forms of chlorine?
Make sure to test Ch level also.
