- Sep 8, 2021
- 241
- Plaster
- Hayward Aqua Rite (T-9)
No and not at all.Will TA change with salt? How worried should I be about that if ph is good?
Is your pool set up as a SwCG pool? If so, minimum FC for 60 Cya is 3 ppm. 5% of the Cya.Also the poolmath app says I'm good at 60 cya 4 fc, but the charts suggest 5 at that cya level. Why the discrepancy?
That was it! It is set as swg, but since for now it is bleach I changed it and viola, I gotta add some bleach!! Thanks!Is your pool set up as a SwCG pool? If so, minimum FC for 60 Cya is 3 ppm. 5% of the Cya.
