- Jun 22, 2014
- 52,078
- Fiberglass
- CircuPool RJ-45 Plus
You can use pucks, but on an interim basis and only when you know your CYA isn't too high to where the pool can handle it. Your CYA was noted at 60 already, so I'd avoid those if you can for now. And the only way to lower CYA is by water exchange - or at least a partial. Other than adding chlorine/bleach manually each day or every other day, an SWG is one option for chlorine automation. Of course there's an up-front cost, but if your schedule stays that way for a long time, it may be something to consider.Can I put pucks in only when I need to for lack of time or is it a one or the other only?
