They did replace both the flow switch and the housing. After replacing the housing my lights did change. With the new housing Instead of coming on for approximately a minute and then shutting off, it now never startsBack in Post #43 you said:
And now in Post #133 you say:
So your plumbing changes have made a difference in the system operating symptoms. Have Cirupool sent you a complete new flow switch assembly? This assemble does include the temperature sensor and I don't see anywhere in this thread that you have replaced it. I think there something going in the rectangle box with the four screws, maybe a bad temp sensor or loose wire connections.
Again, I don't think that the flow switch assembly should be mounted on the vertical pipe section of the cell output side, although I'll admit that i would expect the flow light to be green when the pump is not running.
generating chlorine at all. All the green lights flash on briefly, then immediately the flow switch light and the temperature light turn red and it never generates chlorine. I also can no longer get it to run with hot salt water in the skimmer basket. DSP has a video of the install which places the cell vertically, the instruction manual show it horizontally. At this point they have replaced every part.
