Installed a brand new 1hp centurion century pump motor, turned the switch to 115, black wire to L1 white wire to L2 green to ground, bolted everything up filled pump with water closed lid turned pump on, it ran loudly for 1 to 2 seconds and tripped the breaker, installed new 15 amp breaker tried again and the same thing happened, I wired up the old motor that I was replacing due to noisy bearings and it did not trip the breaker.. checked the wires everything was connected nothing seemed loose or damaged, I’m stumped this pic is of the old motor, the new one is longer and has the switch to change from 230 to 115 instead of switching the brown/white wires thank you in advance for any help/suggestions
