- Apr 18, 2021
- 56
- Plaster
- Pentair Intellichlor IC-60
Moved from HERE
I have very high TA in my fill water as we are on a well. We only run the slide and fountain when it's being used. I feel like I have a good grip on maintaining the pool but want to add Borates. Our plaster was applied in August-is it too soon to add boric acid?We recommend you give your plaster a year to cure and live with your pool for a year or two and see how stable your pH and TA is before you add borates. Once you add borates it takes much more acid to make pH and TA adjustments.
