borax causes cloudy water?
Jul 31, 2017
3
North Fork
Hi, We've been trying to balance our pool water for a couple of weeks. The ph is always low or non existent, but whenever I add the amount of Borax suggested on poolcalculator, the water gets super cloudy. How do I fix it, and is it safe to swim in?
:wave: Welcome to TFP!!!
First, it is NOT safe to swim if you can't clearly see the bottom of the pool.
Second, post up a full set of test results from the K-2006 because the other factor as to whether it is safe or not is your chlorine (FC) level compared to your CYA level.
Do not drain your vinyl liner pool below leaving 1 foot of water in the shallow end!
Did you do the dilution test on the CYA? If you are well above 100, you will most likely need to do multiple drain and refills.
Good luck!
