Borate Drop test
JoyfulNoise
Platinum Supporter
May 23, 2015
15,866
I was wondering if this Drop test kit would be sufficient to do the Borate test in Pool?
https://www.ebay.com/itm/Borate-Test-Kit-/282076111448
I have never purchased from EBAY nor do I want to. If this kit can be used, does anyone know as to where it may be purchased other then ebay. The test strips are just not cutting the mustard.
In my signature is a link to the borate testing method many of us here use. It requires purchasing some additional chemicals (mannitol powder and BTB indicator) but also uses reagents from your Taylor kit.
You could always try that test kit and write a review here for it. I understand not wanting to buy stuff off eBay but the company seems to be reputable. The main difference I can see is that they are using a phenolphthalein indicator which is a pink-to-clear transition. The BTB indicator is a yellow-blue transition which could be easier to see that pink-clear. All depends....
Parabolic
In The Industry
Apr 15, 2018
87
Newport/California
This eBay kit calls it a "Borate Alkalinity" test kit. Is that correct?
