Hi all, my polaris booster pump appears to be leaking at the input and output connections. I'm assuming that these PVC connections are threaded and cemented to the input/output lines?
I'd love to just apply some extra sealant on the connections, but i'm guessing that probably won't be a real long-term fix?
I'm guessing that to fix this I'll need to:
1. Cut the lines above the connection(s)
2. Remove threaded connection(s)
3. Clean threaded connection(s)
4. Install new threaded connection(s) with new inline fitting
Questions:
Standard PVC cement on the inline fittings? or is there a better option?
What about sealant for the threaded connection(s) to the pump?
thanks!
Questions:
thanks!
