Booster pump and salt cell plumbing.
Rcstorm
10
New Jersey
Hello,
I am going to be plumbing in a salt cell to my set up and am wondering if it is a problem to have the booster pump plumbed in after the salt cell? It would simplify my plumbing. In the picture below I would like to add the T for the pump on the vertical side of the elbow on the supply from the filter.
If that is a bad idea any suggestions on how to plumb after the filter to accommodate an IC40 and the booster pump?
Thanks.
I would do a vertical kit and install just after your booster pump, go up and back down into the existing plumbing.. Cut 1.5 inches past your booster pump, install a 90 degree going up and go from there.. Cut of the 90 where it goes into the ground and connect the other end when done.. I would put the flow meter before the booster pump right in the middle.. :)
This is the circupool one but it is same idea for yours..
That one is for curcupool and has different threads than yours... I could not find one for Ichlor SWG..
