Hi. I am replacing a pool pump on an older pool and noticed there is no bonding wire at the pump. I checked the pool. The ladder, handrail and pool light junction box had continuity, so it looks like it has a bonding grid. I will check to see if the pump bonding wire was cut. My question is the pool light junction box. It has a bonding wire connection and an electrical ground wire connection. Doesn’t this create a connection between ground and the bonding grid ? Could a ground fault electrify the bonding grid and create a safety issue?
