Preface: I've watched all the Mike Holt videos and have just been through his process to check my vinyl lined pool. We bought this house in the early fall, swam several times with no issues. The only reason I starting looking into bonding is that I noticed the previous pump was missing a bonding wire.
Here's what I've discovered from the tests:
1. Switch Box for Autocover with Metal Face Plate is NOT bonded - this is a simple fix
2. Metal Cover of Autocover Well is NOT bonded - this shouldn't be too hard to remedy
3. Side Tracks for Autocover are NOT bonded - I'm not sure how tough this will be to fix
4. Auto Cover Front Rail is NOT bonded - I have no idea how to bond this
5. Diving Board bolts are NOT bonded - I'm thinking I'll have to cut into the concrete to fix this
What is bonded: pump, handrails, rope mounts for the deep end divider, autocover motor/mechanics
What I'm not sure of: water bond. On the first round of tests, the water was above the ring rope mounts and the NEV voltage test showed the water was bonded. I drained enough water to test again and came up with confusing results:
Voltage Measurements:
Disconnect Box - .13
Pump Bonding Wire - .13
Rope Mounts - .12
Water - .10
I'm not sure whether the .02-.03 voltage gradient means the water is NOT bonded. I know it's bonded if the water is above the rope mounts, but I don't think they satisfy the 9 square inches requirement. I also don't know if there is any device bonding the water underground potentially at the drain or skimmer such as the Permacast PB-2008. Our handrails don't enter the water. We have a plastic ladder embedded in the side and handrails above the water.
Looking for help and advice to get this fixed.
Rope Mounts - .12
Water - .10
