Hi. I’ve been getting tons of helpful info here, but now it’s time to ask my own questions. Building inground polymer wall pool w/ vinyl liner. Want to make sure light and niche are properly hooked up. Seems electricians even become confused about code on this. Anyway, I have Hayward plastic niche and 12v Hayward LED light. Actually it says 14v on the light itself. Using pvc conduit and planning on running to pool junction box then to transformer. My transformer is Intermatic PX300. My understanding is to bond outside lug on niche to the bonding grid around pool.
The lug on the inside is where I’ve come across several differing opinions with the low voltage lighting. Should I run insulated copper wire from this lug to ground bar in jbox? If so, Does anything else get connected to the grounding lug inside the jbox? Also, What size breaker should I use with this setup? Thanks for any help!
