Hello, Trying to figure out the best options to replace concrete slabs sinking around pool. Rain water ending up in back of pool area, decay of roots from removed trees? Slowly going down through years. The issue with concrete upfront was caused by water leak a few months ago, elbow broken for...
Hi There, Posting the first time. I have a mastertemp 200 that is installed on a concrete platform that is the roof of a small machine room where the pump, filters, etc are located (also installed on concrete). The heater is for a large 8 person spa, and is located in Antigua, Guatemala (which...
www.troublefreepool.com
This one too.
Seems like the preview pictures are downscaled for some reason.
What material should I use to backfill under and around new PVC pool lines? I was thinking sand for under and first 2-4" over lines, then dirt. Please advise. If you recommend sand, what coarseness? Thank you!
