Blue Wave Pool Poles and unlevel water- PLEASE HELP!!!
Jimstan2011
1
Damianis1*
Hello!
I have an 18ft by 52in Blue Wave Pool. I spent two weeks making the ground level all on my own and used a line level, a level by itself, and a level on a 2x4x10 pulling it in a circle with sand and it was all level ground. I checked numerous times before placing the tarp and pool. I am wondering if unlevel pool poles can cause the pool water to be unlevel. It appears I have some poles sitting on higher ground than others. I have about a 2.5in difference in water level, but I noticed that the poles directly across from where the pool water level is higher, are actually higher up than the rest of the poles. (this is not the ground itself where the entire pool is sitting, its just the poles) Could this cause my water to be unlevel?
Thank you in advance for any help in this matter.
