Try entering FC Now/13 Goal/16 in PoolMath, add that amount of chlorine and retest in 15min, see what you are at then.ok, so i shocked to 16 again... interestingly enough, the pool math said i should be at 16, but i am once again at 13... so my guess is there is more water in my tub than the gallons calculated... So I modified that a bit for my pool math app going foward.
Yes the reagents do add a "cost" to the slamok.. that got it to 17... so gallons in my tub is not perfect ill see what we are at in an hour. Certainly isnt cheap to do a slam. feel like im going through DPD reagents like mad haha
I havent... im searching around to try to find the larger sizes.Yes the reagents do add a "cost" to the slam
Have you checked out the bulk refills?
- R-0870 powder (look for the .25lb or 110g size, R-0870-J)
- R-0871 liquid (look for the 16 or 32 oz size, letter F or J, I think)
- make SURE to compare & verify the size
It is better to add chlorine (liquid) than clarifier.I tell ya, the tub saw some pretty heavy use (kids) this weekend. I put in a couple oz of clarifier and BAM gunk again.. I am really confused... I thought clarifier essentially gathered the smaller stuff, grouped and and it should get grabbed by the filters... Im starting to think my filter system is garbage. I get a nice swirl of water and stuff is being filtered out but everytime I add clarifier the walls just get gunked up.
If you FC is good level, it could be causing the clarifier to "gunk" (reaction)There is plenty of FC in the tub. So do I not worry about the fact that the clarifier gets that gunk out? The tub is still pretty clear without it.
