Hi
Above ground 3200 GA
Been choking it using method here and poolmath calculator for 8 years.
I know how to do it and have learned from a lot of my mistakes in the past.
Water has a little foam on the top and when i put my hand in the pool, it feels very greasy (Like maybe too much bleach?)
The pool has been clearing as expected daily.
1)I only use Clorox brand
2)Never splashless or scented.
3) My stabilizer is at 70-80, so according to my table my chlorine should be at 28 until the pool is cycled.
4) Yesterday morning i cleaned the filter cartridge which does not have green anymore. Put it back and started the filter and the foam disappeared. Then it came back like 5 hours later. I went to adjust the chlorine and added what was needed to hit 28. I put the chlorine and withing 1 hour no more foam. Then this AM it is back even if less.
Things that i thought about:
1) Is my stabilizer too high (70-80) and forces me to put too much bleach?
2) My water level is a little high as i forgot the hose in it 3 days ago. I let the sun do it’s thing to lower the water level. Is it that?
3) Clorox changed their formula?
Thxs a lot
Pat
Thxs a lot
Pat
