Sorry for the dramatics, but we just moved into a new house that has a 44k gallon liner chlorine pool. The pool seemed to be running well for a few weeks, and then yesterday I noticed a pretty big black stain in the bottom of the shallow end (3 or 4 feet in size). From reading these posts I figured it was either black algae or some sort of stain. The previous owner had a pool guy who had been using tri-clor in a feeder and who know what else (I shut off the feeder). I'm not great at reading CYA but I'm guessing it is in the 100 range, so I've been keeping my FC levels in the 8 to 10 range with liquid chlorine and hypo cal. Instead of draining the pool, I was hoping to let the CYA come down over time with splash out, and small leaks.
Thinking it could be Black Algae I slammed the pool last night up to 30 FC. Here were my pool stats before the slam, and the water is clear
PH 7.8
FC: 10
CC: 0.5
Calcium: 40
CYA: ~100 (not great at reading this test)
TA: 60
This morning the black stain was twice as big. Picture attached. It's in the shallow end near, but not directly under a waterfall from the hot tub (hasn't been heated recently).
Reading some other threads I took my water to be tested at the pool store, and they said there was no Copper or Iron in the water, and Total Dissolved Solids was 400, and Phosphates were 200.
I have been scrubbing the area with my standard nylon brush, and can't tell it is making a difference. I also went it last night and tried to scrub the area with a puck, but I couldn't tell that it made a difference either.
The only things that have changed recently are:
1. We have had landscapers doing a lot of pruning around the pool the day before. A lot fell in the water, but I think I got it all out.
2. We turned on a slide, which hadn't been used in awhile, and may have had some stagnant water
3. I recently started using the Cal-Hypo (I know it's not part of the protocol, but I didn't realize this could cause a staining issue, and my Calcium was so low I didn't think it could be an issue for years).
The pool store guy wasn't sure if it was black algae or a stain but said to get some vitamin C tabs and put them in a sock and scrub the stain, because ascorbic acid is great at getting rid of stains. I haven't tried it yet, and I wanted to check with the forum.
Any thoughts or help would be greatly appreciated! By the way, the white you see in the left of the picture is Cal-Hypo sitting on the bottom, which obviously isn't doing anything to break up the stain
PH 7.8
FC: 10
CC: 0.5
Calcium: 40
TA: 60
