Hey Everyone,
I know there are a lot of threads on this already...just looking to see what your thoughts are.
At the beginning of July, I had metal stains on the floor of my vinyl liner (liner is old....8-12 years).
Yes I plan to replace it.
So I used a chlorine neutralizer and citric/ascorbic acid to eat the stains away...which worked pretty good.
After which however, the pool balls I was using in my Hayward kept jacking up the pressure until backwashing was perpetual, causing stagnant water.
Everything seemed fine until we went on vacation and the pool was stagnant for a longer period... Black spots started showing up at the end of July.
I switched back to sand and within days the pool was crystal clear and I could see the scope of the black...it's bad.
Tried algaecide (yes I know, I am an idiot
then I went back to scrubbing and shocking but am guessing I didn't stick with it long enough.
So here I am...back on the forum.
TF-100 test results
-FC 4
-CC .5
PH is high (see photo) - Tested while FC at 4 per TF-100
TA 140
CYA - 40-50
Pool Temp (89F) - Yes we are crazy
Salt ~3,000
I just added a 1.2lbs of chlorine granules hoping to both get my FC up to at least 8 and also hoping some will settle on the bottom to help eat the algae.
Just brushed and brushed the pool along with scrubbing with the only mitt I can find that actually helps get this black Crud off.
Backwashed and shut pool heater off.
The pictures were after I brushed thoroughly and scrubbed...so if you see streaks of white...that's me using the red mitt basically scraping it off (it's incredibly tough in the transition to deep end 4-8')
Questions....
According to the FC/CYA 8 is a good FC level to hold during SLAM....right? or should I go higher?
Should I address the PH or wait until after Loss Test is complete?
Is my 5yr old TF-100 test kit too old?
Any other ideas?
Thank you for any advice... as I start SLAM over this holiday wknd....tons of photos attached.
-Brand new SWG this season
~20,000gal inground, vinyl liner needs replacing as it is getting wrinkled
-Hayward s244T sand filter (now back to sand again)
-Jandy PHPF 1.5hp Pump
TF-100 test results
-FC 4
-CC .5
TA 140
CYA - 40-50
Salt ~3,000
Questions....
Any other ideas?
