You have a couple issues at the moment to contend with - stains and algae. There's a chance they could be related, but I've never seen a stain have that "run" effect like a shooting star. That still looks like something was blown into the water (like fertilizer or weed & feed perhaps). Let's start with the algae though. Your CYA is crazy high. Since there's no way our CYA viewing tubes give an accurate number of 100, you might try the dilution CYA test as seen
HERE, starting at Step #8. The CYA for your pool (no SWG) should be no higher than 50 right now. Because your CYA is so high, the FC can't keep up. Once you have an accurate CYA number from the dilution test, then you'll know how much water to exchange to lower the CYA.
Speaking of FC testing, the K-2005 only goes so high. By adding the
FAS-DPD testing portion to your current set-up, you essentially make it a K-2006 kit. That's what you need. That has to be a priority so that you can perform a TFP "SLAM" link below to kill & remove the algae. Remember to follow everything on the SLAM page correctly for best success, to include lowering the pH to 7.2 before starting the SLAM.
Going back to the stains, you can try placing a chlorine tablet on an area to see if it changes. If not, then try some Vitamin C tablets crushed-up and in a sock and let that sit for a little while. I'd start with those two first and see what reaction you get.
